2704n router log
larryvanhowe
2704n router log
I have a Plusnet 2704n router. Is there any way to get a log of activity on the router. I have fibre and find my WAN IP address is changing every 12 hours so I assume my BT connection is getting disrputed briefly causing the change in IP address.
I do not see any option in the web interface for the router. Perhaps, there are some hidden options.
Larry
Tags (1)
5 REPLIES 5
MatthewWheeler
Fixes: 481
Re: 2704n router log
As far as I'm aware it's not possible but you may have some luck with the expert user link below
http://192.168.1.254/expert_user.html
 Matthew Wheeler
larryvanhowe
Thanks, while it is an interesting view of the router, there is no log function. I will just keep an eye on my Helpdesk page which shows the uptime.
etdsaunders
Fixes: 7
I'd personally have a browse ebay for a plusnet hub one or a BT home hub 5.
They are cheap, and don't require a BT modem for fibre! This way you'll be able to monitor things a lot better
Raspberry Pi enthusiast!
If you Like it, give it a Thumbs_Up
larryvanhowe
I already have bought a HH5 on ebay for £15 but still waiting for it to arrive.
Anotherone
Champion
Fixes: 21
There are 3 Uptimes on the 2704n, the Helpdesk page is PPP Uptime.
expert_user.html page, Device Info Uptime is time since last reboot or power up.
expert_user.html page, Device Info Showtime is the time the DSL has been up, or the time since the statistics on the page have been reset if that was done manually.
