2704n Linux Bash Script to Monitor ADSL
- My Router
- 2704n Linux Bash Script to Monitor ADSL
21-01-2017 9:43 AM - edited 21-01-2017 9:44 AM
Cobbled together this script to periodically scrape stats from my 2704n and write them to a .csv file. It's not solely my work - it included elements inspired by darsh from
and
https://gist.github.com/potchin/44cfdf88b31af19ab7dc
Hopefully may be of use to some people.
Written and tested on a Linux Mint 18 install.
Prerequisites
curl installed - sudo apt install curl
xmllint installed - sudo apt install libxml2-utils
Create a suitable empty stats file in .csv format. If you want to create a header row the stats being pulled are:
Date, Time, DSL Uptime, Downstream Sync, Upstream Sync, Downstream Atn, Upstream Atn, Downstream Noise Margin, Upstream Noise Margin, Downsteam ES, Upstream ES, Downstream SES, Upstream SES
Edit the script to add your router's password and the path to your stats file. Save as xxxx.sh and ensure it is set to be executable in permissions
add a cronjob entry via sudo crontab -e to run the script on a regular basis
My crontab entry is is set to run every ten minutes and looks like this....
*/10 * * * * /path/to/xxxx.sh
#!/bin/bash
# scraper script for pulling ADSL data from a plusnet 2704n router
PASSWORD="***********" #replace with your routers password
IP="192.168.1.254" #default
USERNAME="admin" #default
cookiefile=$(mktemp)
tmpfile=$(mktemp)
tmpfile2=$(mktemp)
date=`date +%Y-%m-%d`
time=`date +%H:%M:%S`
stats=/path/to/statsfile.csv #path to your stats file - create this file before running the script
curl -s -c $cookiefile -o /dev/null --data-ascii "loginuser=admin&loginpasswd=${PASSWORD}" "http://${IP}/plusnetlogin.cgi" || exit 1
curl -s -b $cookiefile "http://${IP}/helpdesk.html"> $tmpfile|| exit 1
syncdown=$(cat $tmpfile | grep "var dsldownLineRate"| tr -cd '[[:digit:]]')
syncup=$(cat $tmpfile | grep "var dslupLineRate"| tr -cd '[[:digit:]]')
dslinfo=$(cat $tmpfile| grep "var dslinfo" | awk -F '"' {'print $2'})
attdown=$(echo $dslinfo | awk -F '|' {'print $2'} | awk -F '/' {'print $2'} )
attup=$(echo $dslinfo | awk -F '|' {'print $2'} | awk -F '/' {'print $1'} )
snmdown=$(echo $dslinfo | awk -F '|' {'print $1'} | awk -F '/' {'print $2'} )
snmup=$(echo $dslinfo | awk -F '|' {'print $1'} | awk -F '/' {'print $1'} )
uptime=$(cat $tmpfile | sed -n '/6 - Uptime:/{n;p;}' | awk -F'[<|>]' {'print $3'} )
curl -s -b $cookiefile "http://${IP}/statsadsl.html"> $tmpfile2 || exit 1
esdown=$(xmllint --html --xpath '//tr[position()=42]/td[position()=2]/text()' $tmpfile2)
esup=$(xmllint --html --xpath '//tr[position()=42]/td[position()=3]/text()' $tmpfile2)
sesdown=$(xmllint --html --xpath '//tr[position()=43]/td[position()=2]/text()' $tmpfile2)
sesup=$(xmllint --html --xpath '//tr[position()=43]/td[position()=3]/text()' $tmpfile2)
echo "$date,$time,$uptime,$syncdown,$syncup,$attdown,$attup,$snmdown,$snmup,$esdown,$esup,$sesdown,$sesup" >> $stats
Re: 2704n Linux Bash Script to Monitor ADSL
21-01-2017 10:06 AM
Hi @smurphos - Can you post some of the output from the .CSV file please.
21-01-2017 10:29 AM
Here you go - yes my line isn't great at the moment hence my effort to keep track of what is going on....
Date | Time | DSL Uptime | Downstream Sync | Upstream Sync | Downstream Atn | Upstream Atn | Downstream Noise Margin | Upstream Noise Margin | Downsteam ES | Upstream ES | Downstream SES | Upstream SES |
2017-01-21 | 09:00:01 | 0 days 00:17:05 | 16252 | 1071 | 26.5 | 12.5 | 5.8 | 3.3 | 53 | 0 | 10 | 0 |
2017-01-21 | 09:10:01 | 0 days 00:27:05 | 16252 | 1071 | 26.5 | 12.5 | 5.7 | 2.4 | 58 | 1 | 10 | 0 |
2017-01-21 | 09:20:01 | 0 days 00:37:06 | 16252 | 1071 | 26.5 | 12.5 | 5.3 | 0.3 | 72 | 1 | 10 | 0 |
2017-01-21 | 09:30:02 | 0 days 00:47:07 | 16252 | 1071 | 26.5 | 12.5 | 5.4 | 1.1 | 80 | 1 | 10 | 0 |
2017-01-21 | 09:40:01 | 0 days 00:57:07 | 16252 | 1071 | 26.5 | 12.5 | 5.6 | 3.1 | 99 | 15 | 10 | 0 |
2017-01-21 | 09:50:01 | 0 days 00:01:34 | 15840 | 863 | 26.5 | 12.6 | 6.8 | 8.8 | 139 | 38 | 23 | 1 |
2017-01-21 | 10:00:01 | 0 days 00:11:34 | 15840 | 863 | 26.5 | 12.6 | 6.9 | 9.3 | 141 | 38 | 23 | 1 |
2017-01-21 | 10:10:01 | 0 days 00:21:35 | 15840 | 863 | 26.5 | 12.6 | 6.8 | 9.6 | 152 | 45 | 25 | 2 |
2017-01-21 | 10:20:01 | 0 days 00:31:36 | 15840 | 863 | 26.5 | 12.6 | 6.8 | 9.3 | 157 | 45 | 28 | 2 |
21-01-2017 11:12 AM
Thanks for that @smurphos, shame it doesn't format correctly in the page, but that's not down to you.
- My Router
