2019 - Same old question: USB connected to router. How to?
Mr-Bee
Because of the changes with Windows SMB, has this made any difference to how the USB is shared?
USB is installed and connected but, I can't seem to find it.
\\192.168.1.254\Store
or
\\192.168.1.254\Store\Home
Tags (5)
7 REPLIES 7
VileReynard
Fixes: 20
Re: 2019 - Same old question: USB connected to router. How to?
Rather depends on whether you have downloaded a compatible version of SMB to your router, doesn't it?
Mr-Bee
How to get it to work?
Seasoned Champion
Fixes: 49
You did not say which router you are using? I have a Hub One.
If you looked in "My PC" and expanded Network hopefully you will see PNHUB1 and when expanded you hopefully see usbn where n is a number.
On my router currently I have \\Pnhub1\usb4.
Hope this helps
Dan.
Mr-Bee
I got this:
Error code 0x80004005
This problem may occur if a file that the Windows Product Activation (WPA) requires is damaged or missing. This behavior occurs if one or both of the following conditions are true:
  • A third-party backup utility or an antivirus program interferes with the installation of Windows XP.
  • A file that WPA requires is manually modified.
Does not work on either:
\\Pnhub1\usb
\\Pnhub1\usb1
\\Pnhub1\usb2
\\Pnhub1\usb3
\\Pnhub1\usb4
All I can see is this:
Tags (2)
Seasoned Champion
Fixes: 49
Under Network you should see two sections;
Computers - here I see my network shares
Other device - Here I see the Hub One when I double click the router home page opens.
My network is also setup as 'Private'
Sorry can't help you with the windows error, however this might help you.
https://community.plus.net/t5/My-Router/Plusnet-Hub-One-USB-Storage-Access-Solution/m-p/1542840
Dan.
Mr-Bee
No sign of USB
USB is connected...
Still can't find it!
gmcgough600
@Mr-Bee did you find a solution? Here's my similar post with solution that worked for me:
https://community.plus.net/t5/My-Router/Hub-One-USB-Port-Issue/m-p/1682397/
