2.4ghz not working
- My Router
- Re: 2.4ghz not working
2.4ghz not working
20-08-2021 11:45 AM
Can anyone help? Does anyone have a fix for this? Is it the router thats faulty? I've not been long with plusnet and am already regretting the switch
20-08-2021 12:36 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Router
20-08-2021 5:07 PM
Hi @Pauric88
Thanks for reaching out and I'm sorry to hear that you're having problems here. 2.4GHz is more vulnerable to wireless interference than 5GHzm so simple things such as ensuring that the router is away from other electrical devices can go a long way here. Have you also tried downloading a WIFI analyser to see if you're on the best channel for 2.4GHz?
Resetting the router frequently can have the adverse effect top be honest, so I'd avoid doing that, Openreach's DLM system tends to intervene and slows down the line if it thinks the connection is being intermittent.
