2.4 Ghz much slower than 5 Ghz
- My Router
- 2.4 Ghz much slower than 5 Ghz
- « Previous
- 1
- 2
- Next »
Re: 2.4 Ghz much slower than 5 Ghz
01-02-2020 10:32 PM - edited 01-02-2020 10:32 PM
Are you running these speed tests with no devices using the broadband/wireless apart from the device you're running the speed test on?
Bit stumped if you are and I can only really put it down to interference. Seems unlikely to be a faulty router if you're getting higher speeds on both ethernet and 5GHz.
01-02-2020 10:39 PM
There are several devices connected but asleep but only one actively being used.
Nowhere does it state that there is any limitation on the number of devices connected at once.
I will try to disconnect all but the testing device tomorrow
01-02-2020 10:42 PM - edited 01-02-2020 10:46 PM
If you're running a speed test when a device is for example streaming that's going to affect the test result because that device would be using some of the bandwidth.
[edit]
I'd suggest carrying out the steps explained at: http://speedtest.btwholesale.com before running a test. Obviously you can ignore the part about testing on an ethernet connection in this instance because we're just trying to get to the bottom of your wireless issue. Let me know how it goes.
02-02-2020 6:46 AM
Moderators Note
This topic has been moved from Fibre to My Router
02-02-2020 9:12 AM - edited 02-02-2020 9:13 AM
You also have different network rates for 2.4Ghz WiFi. My guess is your devices on 2.4 are only capable of 802.11g which is 54mbps on a good strong signal with no interference. Some devices may be 802.11n which is 150mbps but you’re never going to get full speed over 2.4 as there is too many factors.
I’d say 45mbps is actually really good for 2.4Ghz.
Only way you will get full speed is 5Ghz on AC WiFi.
02-02-2020 9:51 AM
@Gtunney I have just run a speed test from Asus laptop and get ~43mps, the network properties state 802.11n
Nothing is streaming
does that change your view?
02-02-2020 9:56 AM
Our playstations upstairs connect over 2.4GHz and they can only get 6MBps (48mbps) on downloads.
Can you do a transfer of a large file from laptop to another on 2.4Ghz and see what you get?
02-02-2020 10:07 AM
If you are right, surely the ISP should warn us that we are paying for 76 but will not get that over wifi on non 5ghz devices.
Just checked my phone spec and that it 802.11b/g/n and tat just gave me 43 mps
Are you using the standard PN Hub One router? I have read elsewhere that a 'better branded' router might fix it
02-02-2020 10:12 AM
No I'm afraid they don't as I had the exact same issue with Sky, I was paying for 80/20 fibre but my router could only handle 20mbps over WiFi so I hacked my sky hub and got my own router.
Im using a Netgear D7000 which is an AC1900 WiFi router. I can get 350+ mbps to my iPhone but that is running 5Ghz AC WiFi.
Depending on the amount of devices you have you could buy a 5Ghz AC WiFi adapter for the laptop instead of a new router.
02-02-2020 10:27 AM
What speed do you get on 2.4 on your netgear router?
I am thinking of a DD-WRT router so that I could load my VPN on it to protect everything on my network, but if the 2.4 speed won't go up I may think again
I curently have up to 8 wifi devices with only 3 capable of 5ghz
02-02-2020 10:38 AM
Just set my laptop to 2.4Ghz 300mbps wireless N and I've just got the below on a Local LAN test.
Internet test over 2.4Ghz I've just got 47mbps down and 18mbps but I'm having issues with my line at the moment and can't get above 50mbps even on 5Ghz when it comes to internet.
02-02-2020 11:24 AM
I have switched of everything wifi (except laptop I'm using) in the house - TV, Echo, smart plugs, phones, wife's iPad, but still my 2.4 connections show 3 unknown connections:
Devices currently connected to your Plusnet Hub: | ||||
Network | Device | MAC Address | IP Address | |
2.4 GHz Wireless: | DESKTOP-UVBJ7QM | 19 | ||
dhcpcd-6-8-2-Linu... | 192.1 | |||
ESP_BEDCD3 | 192.1 | |||
ESP_BE9DE7 | 192.1 | |||
5 GHz Wireless: | No devices detected | |||
Ethernet: | No devices detected | |||
USB: | No devices detected |
Any idea what they are? Could they be slowing things down?
02-02-2020 11:26 AM
Forgot to say laptop speed now is 43.3
- « Previous
- 1
- 2
- Next »
- My Router
