2.4 GHz connection needed.
acd696
I have a front door cam which will only operate on a 2.4 Ghz connection. It is becoming increasingly difficult to get it to connect. Is there a way to ensure a 2.4 Ghz connection on my PN hub one.  Replies in simple English please so that my 74 year old brain can absorb.
All replies appreciated
acd696
1 REPLY 1
Fixes: 1,482
Re: 2.4 GHz connection needed.
Split the bands like:
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Click 5GHz tab.
Change 'Sync with 2.4Ghz' to No.
Change the name of the 'Wireless SSID' - I added a '_5' on the end.
Save the changes.
You can then select which one you want per device.
