0x3 Errors
- My Router
- 0x3 Errors
0x3 Errors
05-04-2021 2:54 AM - edited 05-04-2021 2:55 AM
Hello lately i've noticed my router doesn't seem to be very stable i'm seeing a lot of 0x3 errors and was wondering if there's anything i can do to fix this?
From what i've seen a replacement router is needed? how would i go about this and will it recieve the firmware updates that i had to have manually pushed to my current router to fix my wifi issues?
Re: 0x3 Errors
05-04-2021 7:27 AM
As far as I’m aware watchdog resets mean the router’s developed a fault and if you get a new router you’ll need to ask for the ‘new’ firmware update again as it doesn’t look like that’s pushed to the masses yet.
For a replacement try calling 0800 432 0200
