upgrade order clarification ref phone package
squawk7000
Hello
On Monday morning I phoned to order an upgrade to Fibre. All agreed and the go-ahead given.
My question is about the phone package. I already had 'Evenings and Weekends' grandfathered into my account, at £0. and as discussed with the agent it was continuing
Looking at Question #124532690 (which wasn't emailed to me) I see:
<start quote>
A breakdown of your monthly bill is as follows:
Plusnet Fibre Unlimited broadband service: £xx.00 per month for 24 months then £14.99 per month thereafter
Line rental: £185.88 annually (already paid)
Plusnet anytime call plan: £6.00 per month
<end quote>
I didn't order the 'anytime call plan' and it wasn't discussed so why is it in the order confirmation?
On the good side my router arrived within 24hiours, and have received a activation date of 9 May.
2 REPLIES 2
Fixes: 319
Re: upgrade order clarification ref phone package
I'm just looking into this for you.
[edit]
I can't see anything on your account that indicates your call plan was changing so I think that's a error on the agents part but I'll check again on the day your change to fibre happens to make sure.
 Matthew Wheeler
squawk7000
Mathew
Thanks for the prompt reply. Will keep an eye on it and get back if anything unusual happens
Cheers
Ken
