no fibre after 1 month
I ordered fibre broadband around 15th March. Phone was connected same day & fibre activation date was set as 5th April. I contacted Plusnet on 6th April to see why my fibre was still not connected. I was told that the issue was with my previous provider leaving a "marker" on the line. My new activation date would be 20th April. I phoned Plusnet on the evening of 20th April to see why I still have no broadband and was told that this was now BT/Openreach's fault and that I could be "fastracked" and connected in a further 7 days.
What is going on & when will my fibre broadband be connected?
5 REPLIES 5
Legend
Fixes: 168
Re: no fibre after 1 month
Sorry for the problems you've experienced with your order so far. I can see you spoke to one of my colleagues last night who explained the issue is with a 'tag' on the line telling us that there is already a fibre service enabled on the line. Unfortunately this appears to incorrect as there is no provider associated with the tag.
To resolve this my colleague has contacted our suppliers, asking them to update the records about the tag and he'll be in touch once he receives an update, usually within 3 working days.
Thanks for the reply.
Any particular reason why this was not looked in to after my first failed connection date on 5th April?
Fixes: 41
I'd suspect that would be because this kind of 'out of process' order failure is somewhat unusual.  One does not look for the obscure causes first.  It ought not to be possible for there to be an unowned 'tag' on a line, so it would not be a logical thing to look for in the first instance.
Any news on this?
Fixes: 122
I can see an agent took ownership of this on the 20th, I've been in touch asking them to chase this up and update you ASAP.
 Adam Walker
