can i return an uneeded router for a refund?
- My Order
- can i return an uneeded router for a refund?
12-08-2020 10:51 AM
Just moved to Plusnet, activated today, and working well.
I don't require the plusnet router I was sent, as I have my own modem and separate router (a synology 2600ac) which works much better. I have not opened the plusnet router which is still sealed.
I did raise a support question about this, but have received no reply. (#204726197)
Can I return it for a refund?
Re: can i return an uneeded router for a refund?
12-08-2020 12:26 PM
Doesn't seem likely, given that it's free in the first place.
You can request a post-paid bag to return it - otherwise keep it as a spare.
FTTC 40/10 Billion 8800NL
BT technician (Retired)
12-08-2020 12:30 PM
However if you ever have a fault, you will not get support from PN on your current setup - why not keep ot just in case.....
12-08-2020 2:50 PM
Just stick it in the back of a drawer and forget about it, it's good to have a spare just in case.
12-08-2020 3:07 PM
30-08-2020 3:36 PM
Yes that is what I have done.
- My Order
