Why do I need a new BT socket when there's already an existing Openreach socket?
- My Order
- Re: Why do I need a new BT socket when there's alr...
- « Previous
- 1
- 2
- Next »
Re: Why do I need a new BT socket when there's already an existing Openreach socket?
24-05-2022 8:13 AM
Curiouser and curiouser. Just checked Shell Energy broadband they, too, say they'll have to send an engineer around for £60.
However, I checked Onestream, more or less at random, and for their fibre package they too say an engineer needs to come around but they won't charge for it.
And TalkTalk also say an engineer is required to visit the property, however they won't charge for it, either.
Perhaps NowTV is mistaken or will tack on an engineer visit once I've signed up?
24-05-2022 8:26 AM - edited 24-05-2022 8:29 AM
There is almost certainly no working line showing on Openreach's systems since there has been no service at the property for some time. The charge is a 'standard' charge for providing a working line. This might require an Openreach engineer to attend either the exchange, the cabinet or maybe even the property in order to make the neccessary connections to provide a working line.
Some ISP's will pass on (some of) the charge made to them by Openreach but others will not , as you've discovered
24-05-2022 8:27 AM - edited 24-05-2022 8:29 AM
@NewCustomer1 I still think this is incorrect information somewhere in the BT system, or, as a thought has just occurred to me, the property has been empty so long, they need to re-provision it.
Edit:@MisterW has voiced my thoughts more eloquently.
24-05-2022 11:31 AM
@NewCustomer1 wrote:
I'm in a flat that hasn't had broadband for about five years. There's an existing Openreach socket but nothing has been plugged into it for the last few years. And there's been no working phone in the flat for about the same amount of time.
Then it's highly likely that a part, or all, of the external routing has been used for provision or maintenance.
Is there any sign of life if you plug a phone in?
Zen SOGEA 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
24-05-2022 4:20 PM
I agree with this. In addition, if the line hasn't been active for some time, it is likely it's since been re-used by an engineer to connect a neighbouring property, so wouldn't show up as a stopped line we can remotely restart.
Also if we need an engineer to connect the phone line, we'd charge £49.99 whether that's as part of an installation, or even if we're restarting a stopped line, which was stopped on non-BT equipment at the exchange.
If @NewCustomer1 can private message me their full address though, I'll be happy to take a closer look. ![]()
25-05-2022 9:15 AM
Yes, I guess that all does make sense. However, the idea of simply turning on the broadband in this flat has now become a costly, time-consuming affair. I've been making do without it for years, so I guess there's no reason to change it now. I'll wait until an ISP offers completely free installation.
Thanks everyone for your help and information.
25-05-2022 9:45 AM
No problem, it should be straight-forward but appreciate it's relatively costly, if we need an engineer.
Let us know if you've got further questions or there's anything else you'd need help with.
- « Previous
- 1
- 2
- Next »
- My Order
