Where is my router!?
charlotte2892
I have been on hold to Plusnet for over an hour, I have tweeted them, facebook messaged them and messaged them on Instagram and I have had no reply.
My Line went live a few days ago and I have still received absolutely no communication about my router. When will it be sent out and when will I receive it?
I am still within the cancellation period so I will be terminating the contract if I don't get an update as the customer service is already appalling and I've only been with them for 10 days and not even used any internet yet!
3 REPLIES 3
pint
Re: Where is my router!?
Whats your current router?
 that is what router did you have from your previous Internet service provider?
There is a chance it may work with your plusnet service without to much trouble.
 Plusnet are a budget ISP and their routers ( in my opinion) fall under the category of only just about good enough at best.
 the best location for a plusnet router is in its box not plugged into anything, and for you to use your own router/modem instead - take a look at the "my router" sub forum
Alex
Fixes: 13
@pint
The OP didn't mention if they already had a router. Have you ordered fibre?
Also, if they did have a previous ISP and weren't on fibre then they'd need a VDSL router and not an ADSL one.
Hopefully a member of staff may pick this up, and you can PM them with your username so they see when it was dispatched.
Fixes: 1,466
Moderators Note
This topic has been moved from ADSL Broadband to My Order
