Where is my router!?
- My Order
- Re: Where is my router!?
24-07-2020 9:57 AM
I have been on hold to Plusnet for over an hour, I have tweeted them, facebook messaged them and messaged them on Instagram and I have had no reply.
My Line went live a few days ago and I have still received absolutely no communication about my router. When will it be sent out and when will I receive it?
I am still within the cancellation period so I will be terminating the contract if I don't get an update as the customer service is already appalling and I've only been with them for 10 days and not even used any internet yet!
26-07-2020 4:43 PM
Whats your current router?
that is what router did you have from your previous Internet service provider?
There is a chance it may work with your plusnet service without to much trouble.
Plusnet are a budget ISP and their routers ( in my opinion) fall under the category of only just about good enough at best.
the best location for a plusnet router is in its box not plugged into anything, and for you to use your own router/modem instead - take a look at the "my router" sub forum
26-07-2020 5:09 PM
The OP didn't mention if they already had a router. Have you ordered fibre?
Also, if they did have a previous ISP and weren't on fibre then they'd need a VDSL router and not an ADSL one.
Hopefully a member of staff may pick this up, and you can PM them with your username so they see when it was dispatched.
26-07-2020 7:02 PM
Moderators Note
This topic has been moved from ADSL Broadband to My Order
