When will router for upgrade to Fibre Extra be delivered
Arclight
I upgraded to Fibre Extra online last week, and the status of my order is now 'Complete', along with confirmation that a router has been posted '1st Class'.
I haven't received a router, and I've received no confirmation email of when the upgrade will come into effect.
Is the 'complete' status genuine, or just auto-generated?
7 REPLIES 7
Fixes: 417
Re: When will router for upgrade to Fibre Extra be delivered
@Arclight  Welcome to the forum.
If you have upgraded from 40/10 fibre then you don’t need a new router. If you have upgraded from ADSL and you have a Plusnet Hub Zero then if it’s still working you haven’t yet been upgraded.
A useful check is to put your phone number in here. Read through and see if there’s a reference to an open order with a completion date. If so this is the currently programmed date to do the work.  https://my.btwholesale.com/includes/adsl/adsl.htm?s_cid=ws_furls_adslchecker
Arclight
Hi
The wholesale page provides no date nor open order details.
The speed test shows my mbps speed is still very low:  <10mbps
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Orders
Fixes: 417
@Arclight
You didn't say what hub you are using. There's currently two explanations. Either you've not been upgraded or your fibtr connection is running slow. If you're using a hub zero then it's the former. If it's the latter then all you might need to do is drop the line then reconnect.
Arclight
Hi
It's a Hub One. I've tried bouncing it several times over the last few days to no avail.
I'm still getting 40/10.
Could it just be that I've not been upgraded yet?
Arclight
Hi
I can confirm that I am still getting 40/10 in terms of speed.
Is it just a case of my package not being upgraded yet to the 'Extra' aspect?
MatthewWheeler
Fixes: 479
Thanks for getting in touch @Arclight and apologies for the delayed response.
I've placed an order to change this for you which will complete Wednesday morning
Let us know if you're still having issues after then
 Matthew Wheeler
