When will I received my router?
- My Order
- Re: When will I received my router?
25-09-2020 3:43 AM
I signed up for Fibre broadband with plusnet on September 16th and was told by BT that my services would be transferred to them on the 28th September but I have not had any more communication from Plusnet and I have not even received my router yet, so getting concerned things won't be ready in time? Is it normal to not have the router after almost 10 days of ordering?
Phil
25-09-2020 9:04 AM
@boomphil1 Welcome to the forum.
The answer to your question is Yes. They are automatically sent out by fiirst class post to arrive a day or two before your transfer date, They fit through a standard letter box.
Be aware that the date can move depending on Openreach technician availability. Some times whilst the hub gets automatically held back it's not unknown for Plusnet to fail to pass the message on. Providing you have left it to Plusnet to cancel your BT account this should not be a problem.
25-09-2020 9:12 AM
- My Order
