What Router am I getting again? Scrub That, it's a Hub One.
FIXED- Subscribe to RSS Feed
- My Order
- What Router am I getting again? Scrub That, it's a...
11-05-2016 3:17 PM - edited 11-05-2016 3:21 PM
I've just added the phone package to my existing fttc and I was told it comes with a free router with integrated modem but I can't remember what model. Can anyone tell me what I'll be getting?
EDIT: It's a plusnet Hub One. Should've searched the forum before posting, duh!
You know what a turtle is? Same thing.
Fixed! Go to the fix.
11-05-2016 3:21 PM
Re: What Router am I getting again?
12-05-2016 6:51 PM
12-05-2016 6:54 PM
12-05-2016 6:56 PM
12-05-2016 7:02 PM - edited 12-05-2016 7:11 PM
You can leave it or take it down.
I'd keep it as a spare, just in case.
OR won't want it back
12-05-2016 7:05 PM - edited 12-05-2016 7:06 PM
12-05-2016 11:18 PM
OK, router has arrived in a very slim box that fit through the letterbox while I was out. Which was nice.
I've not wired it in yet, just plugged it into a laptop to get things configured. A couple of things I'm not sure about though.
Firstly I have a TP-Link Archer C2 router at present which allowed me to pre-populate the DHCP server with address reservations, as I have a current list of 28 devices and it was very handy to keep certain devices in certain ranges (VMs in the 60s, Media devices in the 80s, etc), but the Hub One only lets you define the address for a device when it's already picked one up. So I'm going to have to go in and change each one to the one I previously use. Annoying, but I have several apps that already expect certain devices to be on certain IPs. For example we have 3 Raspberry PI's running Kodi that are controlled by Yatse on our mobiles.
Secondly, and this may be a deal breaker, the Archer has the ability to bind a MAC address to an IP. This allows me to set up a port forward rule for UDP port 9 to that IP so I can send a WOL packet to wake up a specific PC on the other side of the router. Very handy for getting a foot in the door when I'm away from home and then being able to WOL any other device on the LAN. Unfortunately the Hub One has no option for MAC binding that I can see, so WOL probably won't work through it.
I'll still set it up at the weekend though and see how it behaves. If I get any significant improvements on wired or wireless speed then I might forgo WOL capability. At the end of the day it's a spare router (my 4th!) and a backup fibre modem is always a good thing.
Incidentally my other two Netgear routers are doing sterling service about the house as 2.4Ghz Wireless Access Points giving us approximately 40Mbps from any room.
13-05-2016 3:10 PM
13-05-2016 4:07 PM
13-05-2016 5:54 PM
Cheers Casey. I might try that. Although from your comments about using my old router with PN, I get the impression you think I'm a new customer. I'm not, I've been with PN since 2005 (and on FTTC since 2013). I just decided to move the phone over to PN from BT, and they sent me a free router as a present!
13-05-2016 6:00 PM
- My Order
