Want to keep existing phone number?
bat66
Hello,
I placed a new order for home phone and broadband yesterday. I received a text message shortly afterwards and was told that I will be given a new landline number which I really don't want.
Is there anyway I can keep my existing landline number and if so how do I go about doing this?
Thank you for any help,
Bat66 🦇
3 REPLIES 3
Fixes: 419
Re: Want to keep existing phone number?
@bat66
You should have been given the option when you signed up. I would ring them back, ask for it to be added and if they say it's too hard then cancel the order.
LordFoul
Fixes: 32
Hi @bat66,
Thanks for getting in touch, I appreciate your query.
If the order is in progress then the renumber can only take place after the order completes and any supplier-imposed waiting period has lapsed. The alternative is to cancel your existing order and request the renumber first.
I haven't been able to locate your details, please can you send your username by private message so I can find out what's happening with the order.
Thanks - LF
Fladdyman
Hi there, I have the same issue, potentially. I signed up last night and I am unsure whether I will be able to keep my existing land line swapping from Sky.
Any help much appreciated .
Cheers
Fladdyman
