Upgrage to Fibre Unlimited (FTTC) - Due to complete 13/12 - Not done yet
Gythral8PNC
29th Nov I ordered an upgrade of my service to Fibre Unlimited & was given 13/12as a completion date
3 days later I received the Hub One & on the 6th an email "Your order is now complete" (I assume this meant that you had done your bit about billing and getting OpenReach involved)
On the 8th I got the notice of next DD email for the new amount (to be taken in the next few days)
What is the status of my order & when are OpenReach going to do the change over?
10 REPLIES 10
Chris
Legend
Fixes: 169
Re: Upgrage to Fibre Unlimited (FTTC) - Due to complete 13/12 - Not done yet
The order is due to complete on the 22nd. If you post back when you're seeing the faster speeds we'll arrange a refund for any difference between the costs of the service.
Gythral8PNC
Thanks for getting back to me
Not what I wanted to hear, but I guess I have no choice but to wait & see if the new 'date' is met
Gythral8PNC
Ok my upgrade sort of went live
14.5mb/s Download 18mb/s upload but the router says it is connected @ 76.51mb/20mb
http://www.speedtest.net/my-result/5902998542
so the upstream is as expected but the downstream is throttled by you?
Fixes: 395
Yes, your PlusNet profile hasn't updated from the ADSL setting yet. You could either calls the CSC or try Chat and explain that you've changed to fibre and your PN profile needs resetting or wait for one of the Help team to see this thread and fix it...
Gythral8PNC
CS hungup on me after a 45min wait
I was not rude, just politely explained the situation
Gythral8PNC
Finally got someone on chat, they told me it could be as late as midnight - well that has past as well, the order is still not live & appears to be throttled by PlusNet, as all speedtests show aDSL download speeds, but the portal & router clearly show 70+ mbps download connection speeds, and the link works at 16mps+ upload
Do I now assume that the guy needed to BASH this will next be in on Jan 4th?
Moderator's note by Mike (Mav):Telephone number removed from a public forum.
Fixes: 395
Your Plusnet profile does appear to have updated now. It won"t however take effect until you disconnect and reconnect the PPPoE session.
Chris
Legend
Fixes: 169
All looks fine now, so a disconnect/reconnect is all that's needed.
Gythral8PNC
Thanks, now working as it should
Gythral8PNC
Still not heard about the refund for failure to complete on time & am now investigating why my 20mb/s upload speed is throttled to 4mb/s, which is not what I agreed to
PlusNet more like NONet Sad
