Upgrading to fibre
Benjack
Upgrading to fibre
Hi
My current broadband contract is coming to an end, and i was thinking of going fibre as it wasn't quite cutting it.
I looked at the renewal email i got, but i only get the option for broadband, so i was wondering how to change contract type.
Is there a particular method or is it simply just start a new fibre contract when my current one expires?
5 REPLIES 5
Fixes: 49
Re: Upgrading to fibre
@Benjack
First thing to so is to check what's available for your line.
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Order
adam945
Fixes: 113
Looks like you've got a pretty decent line @Benjack
I've just done a quick check and your line can achieve speeds of up to 80Mbps, and there does appear to be capacity at the local cabinet. Best thing to do here would be to give our Customer Options Team a call on 0800 013 2632 to see what they can do for you. Smiley
 Adam
 Plusnet Help Team - Leeds
Benjack
80 might be overkill for just me, but it should be better than the 5 im currently getting.
Fixes: 49
@Benjack
You'll have a choice - either 40/10 or 80/20
