Upgraded to unlimited fibre extra - but speed still the same.
Bobtheblob
I upgraded to the unlimited fibre extra package on the 2nd April. Received email confirmation that the new package will be active on the 3rd April. However it's now 6th April and my speed is exactly the same, nothing has changed.
When I login to my plusnet account there is an error as follows...
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
Can anyone help, is something stuck?
Thank you.
2 REPLIES 2
Fixes: 237
Re: Upgraded to unlimited fibre extra - but speed still the same.
What does the portal say your product is?
There is some possibility that the update has not happened.
How are you determining that the speed has not changed?
What does the router status page report?
Fixes: 334
@Townman This is sorted on the OPs original topic - I had asked for this one to be locked a good few hours ago.
