Upgraded to Fibre and still have 5Mbps
dreamas
Upgraded to Fibre on 07/04/2020 and got confirmation email that changes will apply on 08/04/2020 and today is 10/04/2020 still got the same 5Mb/s speed even tho on my account it says 40Mbps and the real download speed is nowhere near 5mbps anyways downloading at 500kbps-1mbps
Your broadband service
  • Product: Unlimited Fibre
  • Estimated Download Range: Not available
  • Estimated Upload Range: Not available
  • Minimum Guaranteed Speed: Not available
  • Current Line Speed (Download): 40Mbps
7 REPLIES 7
Fixes: 1,466
Re: Upgraded to Fibre and still have 5Mbps
Moderators Note
This topic has been moved from Fibre to My Orders
kennykleks
I've upgraded to Fibre around 2 months ago. engineers cannot fix simple cables in the cabinet. I was told 6 times that Fibre will be by midnight. Last time yesterday :). I wish you good luck with them.
tinytaco
Fixes: 29
@dreamas sorry to hear this, I have had a look at the speeds you should be getting on your line which shows as this:
Estimated Download Speed: 37 - 40mbps
Estimated Upload Speed: 8 - 10mbps
Your Minimum Guaranteed Speed: 30.mbps
To ensure we are giving you the service we should be, I have ran a speed test for you. I will attach this below shortly. Smiley
 Noor
tinytaco
Fixes: 29
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 662.5
Upstream Rate Assessment Very Good
Technology VDSL
Current 15Min Bin Retrains 0
Last 15Min Bin Retrains 0
DP Type External
Profile Name 0.128M-40M Downstream, Retransmission Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2020-03-30T10:30:00
 Noor
kennykleks
Is it normal if my router is flashing orange every night around 2am for 1 hour then when I'm checking sync speed it shows different speed. For today it state as: 30mbps down and 0.7 upstream. I don't mind that download speeds but 0,7 up is just slowing down everything. Before switch on to Fibre it was 0.5mbps, after 2 days 1.2mbps, 3rd day 0.7mbps. And downstream came from 35mbps to 30mbps.
kennykleks
Sorry, not this post.
dreamas
changed from 2Ghz to 5Ghz and it give me decent speed now 10-15mb/s
