Upgraded from Fibre to Fibre extra
jonpedw
Interested
Completed an Upgrade process from Fibre to Fibre extra on the 23rd March and ordered a new router into the bargain.
So far I'm not seeing a speed increase and I have no new router.
Any help gratefully received.
3 REPLIES 3
plusnettony
Fixes: 18
Re: Upgraded from Fibre to Fibre extra
Apologies, I've found the issue and placed an order to fix it for you.
The upgrade should complete with Openreach systems on Monday. I've also added a note to your account to clarify some billing related things for you.
 Tony T
jonpedw
Interested
thought I would wait a little to see if this resolved my issues.
I updraded from Fibre to Fibre Extra to cure slow speeds bu this doesn't seem to have worked.
The new router arrived and installation was easy, but the connection speeds I am seeing are still really variable and quite often very slow.
speedtest.net reports ~15Mbps down and ~3 Mbps up.
I've had much faster speeds before so I can only assume there is a fault somewhere along the way,
WillF
Fixes: 22
Hi @jonpedw. Together with our network partners at Openreach we are prioritising customers who don’t have a phone line or broadband connection, meaning there might be a delay in Speed Faults being fixed. In the meantime, please raise your speed fault online at faults.plus.net.
 Will
