Upgrade, where to find out when?
- My Order
- Upgrade, where to find out when?
- « Previous
- 1
- 2
- Next »
Re: Upgrade, where to find out when?
21-08-2018 8:04 AM
@Lorri66 are your tests wireless or wired ?
Can you post the line stats from the Hub One
you can get stats from the hub one if you visit http://192.168.1.254 then click troubleshooting and then help desk.
You'll see what speed you are connected at there. Fibre is connected at the fastest speed from day one, then DLM will make changes should it need to.
Have a look at that page, remove obvious things like username/wifi name and post back with them.
21-08-2018 10:05 AM
MisterW thank you, I have taken a photo but what bit tells me what speeds I should get please?
My computer is wireless, bit far to connect directly.
21-08-2018 10:11 AM
@Lorri66 you're looking for the details in lines 6 through 9 as shown in the example below
6. Data rate: 2001 / 20712
7. Maximum data rate: 3933 / 21043
8. Noise margin: 11.9 / 6.4
9. Line attenuation: 37.2 / 28.7
If you have to submit a fault then at some point a wired test is going to be requested. The problem with wireless is that it can be affected by other things as well as the basic line speed.
21-08-2018 10:14 AM
data rate 1616 / 1286
max data rate 1615 / 15488
noise margin 6.2 / 7.0
line attenuation 41.1 / 33.0
21-08-2018 11:11 AM
That's not good, I'm assuming the Down data rate is a typo and it's really 12860 ish. That is well below your Handback threshold from your earlier post. Is the router plugged into the master socket and do you have any extension wiring ?
Perhaps one of the PN staff could post the results from a gea test to see if there's interference recorded
21-08-2018 12:04 PM - edited 21-08-2018 12:04 PM
I've attached a test of your line below.
Test Outcome | Pass |
Test Outcome Code | GTC_FTTC_SERVICE_0000 |
Description | GEA service test completed and no fault found . |
Main Fault Location | OK |
Sync Status | In Sync |
Downstream Speed | 12.9 Mbps |
Upstream Speed | 1.6 Mbps |
Appointment Required | N |
Fault Report Advised | N |
NTE Power Status | PowerOn |
Voice Line Test Result | Pass |
Bridge Tap | Not Detected |
Radio Frequency Ingress | Not Detected |
Repetitive Electrical Impulse Noise | Not Detected |
Cross Talk | Not Detected |
Estimated Line Length In Metres | 1664.9 |
Upstream Rate Assessment | Very Good |
Downstream Rate Assessment | Reasonable |
Interference Pattern | Not Detected |
Service Impact | No Impact Observed |
Home Wiring Problem | Not Detected |
Technology | VDSL |
Profile Name | 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off |
Time Stamp | 2018-08-20T13:00:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 8.3 Mbps | 13.5 Mbps | 11.8 Mbps |
Up Stream Line Rate | 1.2 Mbps | 1.6 Mbps | 1.5 Mbps |
Up Time | 805.0 Sec | 900.0 Sec | 898.0 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2018-08-21T10:41:57Z | 2018-08-21T10:56:57Z |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 23 | 0 |
Errored Seconds | 3 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Unfortunately we can't raise speed related issues during the first 48 hours as the line is still in it's training period.
Just to confirm is your router connected to the master socket in your property?
21-08-2018 12:27 PM
yes sorry typo! 12862
Yes my router is into the main socket, and the router is a new one from plus net.
Pretty sure we guaranteed speeds of 16mb/s and thats why I upgraded as we were only getting 4.5 - 5.
Not sure the extra money is worth it if we only gaining a few mb/s.
21-08-2018 2:55 PM
Thanks for confirming.
I'm afraid we'll have to wait for now but if the speeds don't increase then we'd recommend raising a fault here
23-08-2018 11:08 AM
reported as a fault as still only getting 11.5mb/s.
it did go up to 13 once yesterday but not had that since.
Minimum guaranteed is 16mb/s so I am not happy.
23-08-2018 2:03 PM
23-08-2018 4:40 PM
I have had a text message about an engineer calling but surely I don't need this?? There is nothing wrong with my phone line I just the speed for broadband sorted. I have not responded to it as feel its not necessary.
The last time I rang regarding speed (wasn't on fibre then) the assistant just did something on whilst I was on the phone.
23-08-2018 4:54 PM
23-08-2018 6:15 PM
I rang the help line and spoke with a lovely plus net guy. Went through some tests and basically he has saved an engineer visit by getting me to check the master socket, and broadband is super duper - up to 20mb/s when we plugged direct into the master behind the cover.
means we have a fault in wiring somewhere in the other sockets in the house to try and find. But at least we know now.
He was so good, even waiting while I had to pull out a chest of draws to get to the socket. 10/10 for him.
23-08-2018 7:45 PM
- « Previous
- 1
- 2
- Next »
- My Order
