Unlimited broadband to standard fibre switchover..how long should it take?
zilmark
Re: Unlimited broadband to standard fibre switchover..how long should it take?
Received an email this morning now giving us a switch date of the 4th (tomorrow).
Thanks Gandalf if this is your doing - hopefully by tomorrow evening it’ll be sorted & it’ll no longer like being on “dial-up” speeds!
zm
Fixes: 1,638
Yep. The order was fast-tracked through to complete today actually. Smiley
The email is confusingly referring to midnight (00:00:00) on the 4th, so it should be by tonight.
zilmark
Yes it’s up & seems to be running ok.
Many thanks once again Gandalf.
zm.
Fixes: 1,638
Glad to see that! Aye you should hopefully be able to watch the football now you have a reasonable speed. Thumbs_Up
No problem, let me know if there’s anything else you’d need help with
