Unattended switch from ADSL to VDSL
- My Order
- Unattended switch from ADSL to VDSL
23-06-2021 11:29 AM
I have an older ADSL-only hub, and have just ordered a switch to fibre service.
I planned to install a VDSL capable router when the new service is activated, but the I will be away for a while at the date I've been given for the switchover. Will the old ADSL hub continue working on ADSL until I log in using a VDSL router, or will others in the house lose service from that day until I return?
In another location with Zen internet it worked fine - the ADSL service continued after switchover until it was convenient to change to a VDSL modem, but I don't know how PlusNet handles it.
Mary
Re: Unattended switch from ADSL to VDSL
23-06-2021 11:51 AM
Moderators Note
This topic has been moved from Fibre to My Order
23-06-2021 11:54 AM - edited 23-06-2021 11:54 AM
The only way it will work is if you have an ADSL / VDSL - modem / router plugged in for the switch.
The supplied hub one has both so would work.
I'm assuming that's what happened with you previously as there is no way an adsl only modem/router would work with vdsl and a line cannot support both.
23-06-2021 12:25 PM
Maybe a helpful Plusnet staffer will pick up this post and send you a Hub One straight away. These work on both ADSL and fibre.
Alternatively have you still got your Zen hub, that might be configurable to work on your Plusnet account?
23-06-2021 2:39 PM
Hi, I don't use hubs elsewhere, I use a modem (Vigor 130) and separate router. This location I want to convert to the same set up from an older PlusNet ADSL-only hub.
I've just plugged in the new Vigor 130 and in fact it turns out to automatically hook up to ADSL as well, so I'm hoping it will automatically reconnect when the VDSL service starts. At most I hope it will need power cycling of the modem and/or rebooting the router, which I can maybe talk nother family member through remotely.
The new modem and router are giving noticeably faster performance than the PluNet hub in the meantime, so that's good!
Thanks for your thoughts and quick responses.
23-06-2021 2:53 PM
Hi Mary,
If your modem and router are capable of VDSL I imagine they'd need reconfiguring when the fibre service starts.
Alternatively I'm happy to order a Hub One for you that'll work for both ADSL and FTTC automatically if you'd want?
23-06-2021 3:02 PM
When my line was upgraded from ADSL2+ to FTTC, I was running a Draytek Vigor 130 modem into a pfSense router, and the modem seamlessly reconnected to FTTC at the moment of switchover.
At the time, I knew when the Openreach engineer was swapping my line in the cabinet, so was at home listening to an internet streaming radio station, expecting to hear a drop in the stream (while I was getting on with other things), but the modem reconnected so quickly that the audio never dropped !.
The only signs that anything had happened was the Vigor 130 status page reported the new sync rate, and my ThinkBroadband Broadband Quality Monitor live graph showed a 10ms improvement in line latency.
23-06-2021 5:43 PM
That would be very kind of you Anoush.
Do you need my address or other details, or can you get it from my PlusNet username?
Mary
23-06-2021 6:12 PM
no need to provide us with any details @MG31, staff members are able to locate your Plusnet account through the Community Forum.
Before proceeding though, I must make you aware that there is a £6.99 P&P charge when sending out new routers for FTTC upgrades. Please confirm whether you're happy with this and I'll be more than happy to get it sorted.
23-06-2021 6:18 PM
Okay, fair enough. I presume that will be added to my account charges.
Mary
23-06-2021 6:39 PM
Correct @MG31 this will be visible on your next invoice.
I've now had this processed for you, your Plusnet Hub One will be with you within the next 3-5 working days.
All the best.
- My Order
