Transferring home phone from BT: date passed but nothing happened?
FIXED- Subscribe to RSS Feed
- My Order
- Re: Transferring home phone from BT: date passed b...
26-02-2021 10:17 AM
I have an order in for my line rental and calls package to be transferred in from BT to PlusNet. I've had a letter from BT saying it would happen on 24th February and there is a 'question' 211016976 in the Help Assistant where the last message from PlusNet also confirms that it is set for the 24th. But the question has been closed (not by me), it's now the 26th and nothing has apparently happened.
The line is still active, I can make outgoing calls, but I don't know whether they will be covered by the Unlimited Calls package I've ordered from PlusNet, or if BT will still be charging me for them (or if I'm between suppliers and nobody is currently charging me, but somehow I doubt it 🤔 ).
Any insight would be appreciated.
Fixed! Go to the fix.
Re: Transferring home phone from BT: date passed but nothing happened?
26-02-2021 11:48 AM
@bobminors in terms of the actual phone service you won't notice any difference. If you log in to your Plusnet account and click the 'Phone' tab , then that ought to show whether your Phone service with PlusNet is active.
26-02-2021 1:59 PM
Thanks for replying. MisterW. Yes, I've looked there and it says my order is being processed so I'm assuming it hasn't been done yet. Also, Home Phone doesn't appear (yet?) in my list of products.
I'm a bit puzzled as to why, if the same date has been agreed on both ends, it hasn't triggered any action by PlusNet but it's not critical as long as it happens eventually.
I'll make the pessimistic assumption that BT are still charging me for calls.
Or maybe I'll phone PlusNet and ask them what is going on.
Or maybe I'll just wait.
26-02-2021 2:21 PM
Ok, so that does sound like the transfer hasnt happened yet. Not sure why it would be delayed, its not like it needs an engineer to do real work, its just a computer change.
26-02-2021 2:41 PM
Hi Bob,
I can see the line transfer from BT was carried out on the 24th but due to agent error we hadn't automatically updated your account to show this. I've manually triggered the order to complete in our systems, this can take up to 24 hours.
Any calls you've made since we had your line won't be chargeable by us or BT due to the error. We'll start charging you for line rental and your call plan when the phone order's completed (you'll receive an email to confirm once it has been)
Apologies for the confusion we've caused. Let us know if there are further issues.
26-02-2021 3:45 PM
Thanks very much, @Gandalf that's what I wanted to hear. It's all come through now and everything's fine.
26-02-2021 3:53 PM
- My Order
