Transfer in progress. Should I be able to send emails before activation date.
- My Order
- Transfer in progress. Should I be able to send ema...
12-05-2016 8:49 AM
Hi, I am currently in the process of Transferring my Broadband from BT to Plusnet. Although the transfer hasn't completed yet I can receive email on my new Plusnet address.
Should I also be able to send emails or will I only be able to do that once the transfer is complete.
When I try to send an email from my plusnet account from my MAC (MAIL) I get the following message:
recipient rejected - relay denied.
Re: Transfer in progress. Should I be able to send emails before activation date.
12-05-2016 8:59 AM
you can only send via the Plusnet server once your account has gone live - until then you will have to use the BT server
12-05-2016 9:52 AM
12-05-2016 6:54 PM
13-05-2016 7:19 AM
Thanks Casey. That's good to know.
17-05-2016 11:31 AM
@Casey wrote:
They said that it would auto-correct itself when the fibre was up and ready - until hen, use BT as normal.
That is a bit unclear: once you are connected to the PlusNET network and / or you account becomes active, you will automatically be able to use PlusNet's SMTP relay servers. HOWEVER you still need to manually change the SMTP server details in your email program - they will not auto-correct.
Note when not connected via the PlusNET network, the relay servers require authentication credentials (mailbox name and password) to allow use of them.
17-05-2016 4:41 PM
17-05-2016 4:48 PM
I am sure you knew what you meant however there are some around here who might think this stuff all self configures when things change ...
- My Order
