Temporary dual login
My daughter has just started 'proceedings' for her new Plusnet BB & Phone setup.
We've opted to use an existing Asus router which was my old RT-N66U. I've tested it and it's all setup for PN and works fine on my account and now removed again.
When the Openreach engineer arrives and installs the modem and we connect the Router it's presumably initially going to try and connect to my account before I change the username and password.
Is this initial duplicate login going to give anything a 'headache' at PN HQ ?
Let's be careful out there !
15 REPLIES 15
Fixes: 953
Re: Temporary dual login
That’ll be perfectly fine, our hardware management platform won’t recognise a third party router but it’ll still be able to connect to the internet using their login details assuming the router is compatible to the type of broadband service they’ve ordered i.e. fibre or ADSL.
Hope this helps.
@Gandalf  I think the OP is suggesting that when the router is initially connected, there will be two connections using the same credentials until it's reconfigured with the daughters username/password.
However I think we have a more basic problem here
@Kremmen Openreach no longer supply modems!. AFAIK the RT-66U is just a router , so you will either need to obtain a separate VDSL modem or get a replacement vdsl modem/router.
Fixes: 953
@MisterW thanks for the clarification. If the OP doesn’t have a static IP, it’ll still be perfectly fine. If they’ve got a static IP then they’ll both experience data transfer/throughput issues until they’ve reconfigured the router correctly.
Ah, so no modem supplied anymore !!!
I guess that she needs to get in touch with PN and get their Modem/Router then ?
= oops
I do have a fixed IP but it seems that my original query has been superseded with no free Modem anymore Sad
Thanks to all for the info
Fixes: 953
Thanks for getting back to us @Kremmen
Unfortunately not, we moved on from Openreach modems in 2016. If you're/she's wanting to use her own router, I believe these modems can still be picked up albeit second hand from eBay etc. Obviously we wouldn't be able to support her with it as it'd be classed as third party equipment still.
There's also an option of buying a third party all in one modem router, which may give better WiFi coverage. Having said that I'd personally take the free modem router we offer and see how it fares before spending money on extra equipment.
Let us know if you need any further support.
We now have a PN Modem/Router on order, delivery a few days before connection, so she can get connected and see how it performs.
Only issue now is that she only has an old 1980's single plug BT socket. I was told by PN tech that all new fibre connections come with a NTE5C as using microfilters has proved unreliable.
Hopefully that is correct ?
Fixes: 953
Fibre orders are what’s called self install since 2016 which means that an engineer won’t go inside their property to complete the work. Having said that, if we’re arranging an engineer visit on the back of a new line installation then I’d expect the engineer to renew the socket if appropriate.
Fixes: 1,112
Moderators Note
This topic has been moved from Fibre to My Orders
So it's an unknown at the moment.
Find out next week.
BB install all happened, all OK, speed fine, but as expected - a microfilter dangling out of the 1980's BT LJU socket.
Looks like a self install VDSL NTE5C then Sad
Fixes: 953
That's disappointing, before you replace the socket yourself it may be worth seeing how the fibre service performs as while really old (Older than me!) it might be OK.
Let us know if there are any issues though.
TBH it seems OK.
She's getting almost the 40/10 she's paying for.
just me and the dangly filter thing.
And that's using the supplied PN Hub so no need to change that either.
Fixes: 953
@Kremmen It's good to see her speeds are OK 👍 unless you'd want to renew the telephone socket in my opinion it may not be worth it unless she experiences performance or connection problems.
Feel free to let us know if any issues do occur or there anything else you'd need help with.
Thanks 😊
