Switching to Plusnet FTTP
PSD248
I am switching from Shell Energy FTTC Fibre Broadband to Plusnet FTTP Broadband shortly. Anyone know if I should contact my current provider to let them know. The Plusnet website suggests that I don't need to contact my provider and that they will do that. However, the OFGEM website suggests that when moving from FTTC to FTTP I will need to contact my current provider.
7 REPLIES 7
Fixes: 118
Re: Switching to Plusnet FTTP
@PSD248
As far as i know you shouldn't contact your current provider though with FTTP it might be different.
Just to confirm you know PN don't offer a phone service.
PSD248
Thanks for your reply. Yes, I knew that PN FTTP does not have a phone service when I signed up. Will see how we do without a landline. Hoping that PN might offer a Digital Voice service in the future or might try a VOIP service.
Fixes: 480
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 587
@PSD248 unless you've selected the option to 'keep your existing phone service' when ordering the upgrade, then PlusNet will request a 'change of supplier cease' vai Openreach , which will inform your existing supplier and cancel your FTTC and phone service.
maureengaunt
I have just signed up for full fibre broadband. When the engineers have been do I need to connect the router to the new box that will be installed. Does it also need to be connected to my computer as well or can it be in a totally different part of the house
Fixes: 392
@maureengaunt When the engineers have installed the Optical Network Terminal inside your house you will need to connect the Hub to it with the supplied ethernet cable.  If your 'computer' is a desktop, then you will need to connect that to the Hub eith another ethernet cable - unless it has a Wi-Fi card installed (unlikely). If it is laptop, then no.
Fixes: 118
@maureengaunt
Your starting point is where your current copper cable comes into the house. There is some leeway as to where the Optical Network Terminal (ONT) is installed but it must be within one metre of a power source. As mentioned, the Router is connected by an Ethernet cable to the ONT.
As there is an 100 meter limit on Ethernet cables the router can go where ever you're happy to run cable.
If the new router is installed where your current one is then nothing changes within the house network apart from the internal WiFi identifier (SSID).
