Switching from BT
mark1892
Switching from BT
Hi I recently tried to switch from Bt but the order had exceptions onthe line forcing delay after delay.
This should have been a simple switch as all installation work for full fibre was completed by BT previously.
I've contacted bt to help explain the hold up and been told plusnet never contacted them to release/switch.
Is this normal?Huh
6 REPLIES 6
Fixes: 585
Re: Switching from BT
Bt would be notified automatically when an order is accepted by Openreach. If the order is being rejected due to exceptions then that would explain why they haven't been notified
mark1892
So what causes an exception?
Fixes: 585
When there's some inconsistency in Openreach's database e.g address misnatch
mark1892
So I have no way around this? I've had to unfortunately cancel my plusnet switch and now stick with bt
RealAleMadrid
Fixes: 68
@mark1892 Why have you had to cancel, were Plusnet unable to get Openreach to sort things out and place an order that was accepted?  You have given no information on what was causing the problems, maybe you don't know the details but Plusnet should have kept you informed. Is your Plusnet account still active. you may be able to log in and look at tickets (questions) that could explain what's happened.  Plusnet Tickets
Fixes: 480
Moderators Note
This topic has been moved from Broadband to My Order
