Still no word on a broadband start date...
- My Order
- Still no word on a broadband start date...
12-07-2020 6:59 AM
Re: Still no word on a broadband start date...
12-07-2020 8:52 AM
Thanks for getting in touch @hohoholmes
I'm sorry for the problems with transferring your service from your existing provider. I've looked into this for you and I can see that the transfer order has been rejected by our suppliers due to a system issue. Once the order's cancelled in their systems I'll re-place the order and we'll confirm the transfer date.
Unfortunately once we've placed the order this will be at least 10 working days in to the future still because the standard, minimum lead time starts when the order's accepted by our suppliers and there isn't anything we can do to speed this up. In the meantime, if you're having issues with your existing service I'd advise raising a fault with the existing provider.
I'm taking this on personally moving forward and I'll provide an update later on today or tomorrow at the latest.
12-07-2020 9:07 AM - edited 12-07-2020 9:10 AM
@hohoholmes wrote: My partner is a key worker working from home and I switched to plusnet because of the problems were having with sky broadband being slow.
As@Gandalf says if you have problems with your existing service, get them fixed. Changing supplier will not change the cabling route that the internet takes to get to you. You will still have a slow connection if there are local network issues i.e. line faults etc.
Edit: presumably you've been here to see what you should be getting.
12-07-2020 10:13 AM
12-07-2020 10:13 AM
12-07-2020 10:30 AM
Thanks for getting back to me @hohoholmes
I can see this was done and the order was rejected because the previously rejected order wasn't fully cancelled in all supplier systems. Unfortunately there can generally only be one order open in Openreach's system at any one time. Once that's fully cancelled I'll personally re-place the order
12-07-2020 11:39 AM
Moderators Note
This topic has been moved from ADSL Broadband to My Order
19-07-2020 11:28 AM
Hi, I contacted sky and they said as far as they're concerned there is no issue and services with them will be cancelled on 29th July.
Am I able to cancel the switch with yourselves as its becoming too much hard work for something which should be simple.
My partner and I are both now working from home and I can't afford the possibility of going without broadband.
Would I receive a refund for the initial payment I made to yourselves?
19-07-2020 4:14 PM
Hi @hohoholmes,
Thanks for getting in touch.
I'm sorry to hear you wish to cancel your orders. I can see they are on track for the date mentioned and I would say the orders should go through despite your recent experience, however I appreciate your apprehension about working from home, it is ultimately your decision.
If you wish to cancel your orders and leave us, please speak to our Customer Options Team on 0800 013 2632, between:
08:00 and 20:00 Monday - Friday
09:00 and 19:00 Saturday
09:00 and 18:00 Sunday
Thanks - Tahir
24-07-2020 11:04 AM
25-07-2020 8:30 AM
Thanks for getting back to us.
This has been processed for delivery for you, as our hardware is sent Royal Mail 1st Class I'd expect the router to be with you very shortly.
Let us know if you need anything else.
28-07-2020 10:38 AM
28-07-2020 3:59 PM
Thanks for getting back to us @hohoholmes
I understand your concern and I just tried to call you today to discuss this but there was no answer.
I can see we've dispatched your router this morning and you should receive this within the next couple of days. As per my update via ticket 203437854 on 16th July though, we're only currently transferring your phone line to us, because the broadband order failed in the system advising "Cease order in progress" which may indicate that your existing provider is in the process of stopping the active broadband service rather than allow us to take it over.
Once your phone line is transferred to us, I'll place another order to transfer your broadband across to us or if your broadband's ceased then I'll place an order to reprovide broadband back on to the line as quickly as we can.
It may be a bit late now but if you haven't done so already I also advised that in the meantime to contact your existing provider to confirm they've not placed an order to stop your service as this would leave you with downtime.
28-07-2020 8:49 PM
28-07-2020 9:09 PM
It is happening because you asked your current supplier to cancel your broadband.
Unless you were with Virgin media, phone and broadband provision should be new supplier lead. BT systems can only have one order on a line at any one time, so if you cancel with your supplier, your new supplier can't place an order until the first order completes.
- My Order
