Sanctuary warden alarm system
- My Order
- Re: Sanctuary warden alarm system
- « Previous
- Next »
08-10-2025 10:01 AM
Thank you guys, so that means what internet @New_ff2025 has won't affect the warden alarm.
08-10-2025 10:08 AM
That would seem to be te case, but I don't believe any of us are in a position to confirm that. It needs the management of the system to confirm that.
08-10-2025 10:09 AM - edited 08-10-2025 10:10 AM
08-10-2025 10:13 AM
@New_ff2025 please let us know how it goes.
08-10-2025 10:22 AM
08-10-2025 10:46 AM
Good luck. It is sadly one of those things that needs somebody at your property to work out what is going on. we can only guess.
08-10-2025 11:49 AM
Good morning,
Your scheme should have its own telephone line in, so if you're getting your own private connection, you should have nothing to worry about.
That intercom connects to the central control unit somewhere in your scheme and that is connected via the telep[hone line they have.
You shouldn't have anything to worry about.
Thanks.
Ben.
08-10-2025 11:57 AM
That would tend to confirm our deductions from looking at the manual. The system is completely independant from your broadband or phone connection.
So changing from Sky Full fibre to Plusnet Full fibre with the associated loss of phone service, should have no effect on its operation.
08-10-2025 12:05 PM
on
09-10-2025
10:46 AM
- last edited on
09-10-2025
11:24 AM
by
Good morning all, I'm connected to Plusnet. I scanned the QR code and instantly got connected. I also have good news that my warden alarm system is working ok.
I got an email from Sanctuary.
Thank you for your email.
Please be assured that your broadband service does not affect the warden call system. The system is hardwired into the property and operates via its own dedicated phone line. You are therefore free to change broadband providers without impacting its functionality.
Kind regards
<Redacted>
Housing Officer
Sanctuary Housing Association
Personal information removed from a public forum (to an area that staff can see).
09-10-2025 11:11 AM
That is fab news ....
09-10-2025 11:23 AM
09-10-2025 11:54 AM
Reply better late than never I suppose...
Yes but now I have to get all my CCTV cameras and WiFi gadgets to work
Change the wifi name (SSID) and password on the Plusnet Hub to be the same as the previous ones on the Sky router. All your wifi devices should then connect automatically.
09-10-2025 12:05 PM
- « Previous
- Next »
- My Order
