Router not received
Fixes: 387
Re: Router not received
Yes, but @MisterW is asking if you currently have a router, and if so, which?
kel1
Let me check. If I can borrow a router from my friend, will the Plusnet router still be delivered? Or missed?
Fixes: 387
Do you actually have one, without borrowing?
Fixes: 387
@MisterW Post 13 suggests to  me that PN have missed placing the Hub despatch order, for some reason?
Fixes: 583
It does!. Another missing router thread appeared this morning. Hopefully Bob will respond to your tag. If not I'll escalate this and the other thread.
Fixes: 387
Spotted the other one, busy elsewhere ATM.
kel1
I have found my old router: Netgear R7800
In router admin page:
"PPPoE DSL Internet Connection Detected"
It requires User Name and Password.
Seems not working.
Fixes: 583
@kel1 look at pages 26 & 27 of the R7800 manual .
Select Yes for Does my internet connection require a login.
Select PPPoE and enter username and password. Username is your plusnet accountname followed by @plusdsl.net and the password is the one used to login to the member centre. You selected your accountname ( and password ) during the signup.
Leave all the other settings as default.
That should then connect
kel1
It works! Thanks a lot!!
After the new router arrives, I can try to compare it with the old router.
