Router new set up not working
- My Order
- Router new set up not working
14-06-2020 10:39 AM
Phone line is fine
Laptop won’t connect on ethernet cable
reset several times
And nothing ?
Re: Router new set up not working
16-06-2020 5:28 PM
Hi Esther,
Thanks for getting in touch, I'm sorry to hear of the issue.
I've checked the line and it is connected and synchronising at above the minimum speeds for your product. There does not appear to be a fault.
If the issue is still happening please connect your router to the testsocket with an ADSL microfilter.
Please refrain from resetting the router as this can be classed as a disconnection by the dynamic monitoring systems, which may result in the speeds slowing down to compensate for the disruptions.
Please also ensure your router is connected correctly.
If the issue continues you can raise a fault or come back here.
Thanks - LF
- My Order
