Router Replacement
- My Order
- Re: Router Replacement
Router Replacement
05-04-2019 5:43 PM - edited 05-04-2019 5:44 PM
So i was going to upgrade my package because it's about time but i also need a new Hub One Router as the WiFi is starting to well, break.
before this goes any further i went through all the fixes the internet could give me and factory reset it all and spoke to live support, it lasted about 6 hours before the issues began again.
So the only option I can see is a replacement but I can't see how to go about getting one, when I went to upgrade my package it has the option to add one I think.
it says "You will need to have a fibre enabled router,are you sure you don't need one?" with a button the "change this" but it doesn't work.
Not sure where to go from there and i don't want to upgrade until i know I can get the replacement router.
Thanks for any help
05-04-2019 6:27 PM
Hi @beemer530, thanks for your post.
The best way to ensure that you receive a new router on re-contracting would be to call the Customer Options Team. They are contactable directly on 0800 013 2632 and they are open between the following hours:
Monday - Friday: 08:00 - 20:00
Saturday: 09:00 - 19:00
Sunday: 09:00 - 18:00
When you speak with an advisor, simply inform them that you need a new router and they'll get one dispatched right away.
05-04-2019 6:55 PM
Moderators Note
This topic has been moved from Fibre to My Order
