Renewal Offer Not Clear - Line Rental Saver ?
- My Order
- Re: Renewal Offer Not Clear - Line Rental Saver ?
05-05-2020 4:49 PM
05-05-2020 4:55 PM
Hi there, if you have existing Line Rental Saver then it will not be impacted. The £19.99 is explaining what monthly line rental will be if you do not renew. When you complete the steps, the email will confirm this. You have already paid for your line rental, so we will not ask for it again until your existing annual payment expires.
05-05-2020 5:02 PM
You need to be very careful here. If both your contract and LRS end at the same time then unless there has been a recent update to Plusnet's software you will hit a problem. If you update your contract you will find that you cannot add LRS until the next billing month as you can only have one change active at a time. When I renewed I had to ring in and get an agent to add the LRS and a new contract together.
05-05-2020 5:14 PM
When I started the current 12 month contract just under a year ago, I paid for the broadband and line rental in one chunk all at once..., £174 as I recall.., and have therefore paid nothing since. So everything ends at 6th June.
So, is there, in Step 3 of the renewal process some mention of paying for all the new 12 month contract in one chunk with a new Line Saver Rental agreement, or does the renewal completely assume a monthly direct debit of £19.99....?
or.... is there some kind of problem along the lines of what Baldrick1 mentions above ?
- My Order
