Ready for activation early
- My Order
- Ready for activation early
11-10-2016 5:44 PM
BT disconnected my broadband at midday and the hub1 now shows all green apart from t'internet light. It's not due to activate until end of tomorrow. Who do I need to contact to request activation now as it should be good to go, correct?
Many thanks in advance.
Re: Ready for activation early
11-10-2016 6:38 PM
Exactly the same happened to me. You will have to call customer services (yes i know it might involve a lengthy wait on a rep) but when i got a rep it was sorted within 5 minutes.
11-10-2016 6:52 PM
11-10-2016 7:47 PM
Good evening,
Looking at your account it seems you got through on the phone and have been active just over 5 minutes hopefully all works well for you, if you have any issues just let us know
11-10-2016 8:19 PM
Yes, thanks very much. Was a while waiting but all sorted withing a few minutes.
One other question, my router access page doesnt allow me to go to any other tabs (they show as white not pink so I cant change any settings). Is this an initial setup thing? Many thanks....
12-10-2016 9:17 AM
12-10-2016 6:49 PM
See the attached photo. Same issue after a reboot & on iMac, iPhone & iPad...?
13-10-2016 12:33 AM
I take it when you try to tap on another tab, nothing happens? Have you tried a factory reset of the router?
13-10-2016 4:38 AM
Correct, nothing happens. How do I do a factory reset?
13-10-2016 8:00 AM
The router will then start to reboot.
