Probably a daft question around activation date/time
charltjr
In the predicted line activation part of the order tracker, it gives a date of 08th Nov 2016 - After 12pm
Does that mean after 12 midnight on the 8th (i.e. the 9th) or that it's predicted to be activated on the 8th, i.e. after 11:59pm on the 7th?
Or is it even simpler than that and it's the afternoon of the 8th, i.e. after 12 noon?
Hope that makes sense Smiley
Cheers,
5 REPLIES 5
MattyC
Champion
Fixes: 46
Re: Probably a daft question around activation date/time
Welcome back John, you weren't away for long Smiley
Your order has actually completed today, so I have just activated your account for you. Are you ok to let me know if you can get online or not?
Matty
charltjr
Thanks Matty,
A house move forced a change of ISP, PN were more or less the best value and with my previous good experience it seemed like a no-brainer Thumbs_Up
I'll plug in and power up the router when I get home, fingers crossed.....
Cheers,
charltjr
All good Thumbs_Up
Connected first time, speed is a blazing 12 down 1 up, on fibre! Oh yeah, feel the white heat of technology Cheesy
To be fair that's exactly what was predicted and isn't PN's fault, just a consequence of where I'm living relative to the exchange and cabinet. The link seems to be rock solid (famous last words) and is perfectly fine for streaming video and general use, can't help noticing that my Steam updates are a *little* slower now I'm not on a 300 link any more though...........
Thanks again Matty.
MattyC
Champion
Fixes: 46
Still twice the speed that I sync at Grin
Glad to hear you're online.
Matty
charltjr
6?!
I'll shut my whinging trap Thumbs_Up
