Probably a daft question around activation date/time
- My Order
- Re: Probably a daft question around activation dat...
07-11-2016 3:16 PM - edited 07-11-2016 3:23 PM
In the predicted line activation part of the order tracker, it gives a date of 08th Nov 2016 - After 12pm
Does that mean after 12 midnight on the 8th (i.e. the 9th) or that it's predicted to be activated on the 8th, i.e. after 11:59pm on the 7th?
Or is it even simpler than that and it's the afternoon of the 8th, i.e. after 12 noon?
Hope that makes sense
Cheers,
Re: Probably a daft question around activation date/time
07-11-2016 3:31 PM
Welcome back John, you weren't away for long
Your order has actually completed today, so I have just activated your account for you. Are you ok to let me know if you can get online or not?
Matty
07-11-2016 3:35 PM
Thanks Matty,
A house move forced a change of ISP, PN were more or less the best value and with my previous good experience it seemed like a no-brainer
I'll plug in and power up the router when I get home, fingers crossed.....
Cheers,
08-11-2016 8:54 AM
All good
Connected first time, speed is a blazing 12 down 1 up, on fibre! Oh yeah, feel the white heat of technology
To be fair that's exactly what was predicted and isn't PN's fault, just a consequence of where I'm living relative to the exchange and cabinet. The link seems to be rock solid (famous last words) and is perfectly fine for streaming video and general use, can't help noticing that my Steam updates are a *little* slower now I'm not on a 300 link any more though...........
Thanks again Matty.
08-11-2016 9:46 AM
Still twice the speed that I sync at
Glad to hear you're online.
Matty
08-11-2016 5:38 PM
6?!
I'll shut my whinging trap
- My Order
