Phone service and broadband activated at different times
- My Order
- Re: Phone service and broadband activated at diffe...
- « Previous
- 1
- 2
- Next »
Re: Phone service and broadband activated at different times
06-07-2018 9:22 AM
I don't think the occasional drop will affect how DLM treats your line but regular or frequent drops will likely.
With stability and time DLM may provide your line a 3dB target again.
07-07-2018 11:19 AM - edited 07-07-2018 11:20 AM
08-07-2018 1:36 PM
Hello @champ38,
I have looked at your connedction and can see you have had 2 drops over the last 3 days, which is within what we would expect. Please continue to monitor and lets us know if this does increase.
08-07-2018 3:51 PM
I'd like to rule out a cap on my speed at this point; I think I read other posts about other people's speeds that were mistakenly capped. I'd like to rule out other causes at this point so that the only remaining factor is the DLM.
09-07-2018 8:16 AM
Raw speed is not everything - the connection needs to be stable and have a low error profile ... which does require a graded speed.
09-07-2018 1:37 PM
From what I can see there's no banding or cap on your line:
"Profile Name0.128M-80M Downstream 3dB, Retransmission High - 0.128M-20M Upstream, Error Protection Off"
Looks like you're now at a 3dB SNR too giving you a sync rate of 59.6mbps.
09-07-2018 10:51 PM
Speeds are looking more healthy tonight. Ran a wired speed test and download was approximately 59.5Mb and upload was approximately 9.5Mb. Wireless speeds aren't as good even though I'm sat less than a metre away from the Hub One. I might give my old BT Smart Hub 6 a try.
10-07-2018 11:23 AM
Hi @champ388,
I'm glad to hear that the speeds are starting to look more healthy through a wired connection. In regards to the wireless, this won't always be able to achieve the same kind of speeds that you're able to achieve through wired connections, however if you do seem to be having any issues it's worth clicking here and going through our guide for getting the most out of your wireless signal.
10-07-2018 7:00 PM - edited 10-07-2018 7:01 PM
I setup my BT Smart Hub 6 this evening and already the upload speed has increased to 11.2Mb over wireless, which is strange because only yesterday the upload speed was about 9.5Mb via with Hub One. Download is still hovering at 59.5Mb. The downstream is 68.25Mbps and upstream is 11.19Mbps. I'll keep the Smart Hub 6 plugged in to avoid the DLM suspecting instability on my line.
13-07-2018 7:48 AM
13-07-2018 10:28 AM
Glad to hear this @champ388
- « Previous
- 1
- 2
- Next »
- My Order
