Phone line switched but no router delivered I HAVE AN INTERVIEW AND NEED INTERNET
- My Order
- Re: Phone line switched but no router delivered I ...
10-07-2020 2:49 PM
Re: Phone line switched but no router delivered I HAVE AN INTERVIEW AND NEED INTERNET
10-07-2020 3:07 PM
PlusNet don't insist on you using their router. If your old supplier was BT , then its likely possible to reuse your old router.
10-07-2020 3:28 PM
Today my last supplier disconnected me the Internet. 😡😡😡
It takes is a very long and I do not any email with information what with my Internet.
Fee charged but router not delivery😡
10-07-2020 3:39 PM
10-07-2020 4:24 PM - edited 10-07-2020 4:44 PM
What model router was the Post Office one ?
If it's the Zyxel 3925 then this https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/Problems-setting-up-a-Zyxel-router/td-... should help
The plusnet username is your account name followed by @plusdsl.net and the password is the one you use to login to the member centre
10-07-2020 5:03 PM
10-07-2020 5:55 PM
That should be able to be configured, as long as you haven't moved to a Fibre product.
10-07-2020 7:07 PM
10-07-2020 8:05 PM
Yes, the 1302 isn't Fibre(vdsl) compatible I'm afraid.
10-07-2020 8:10 PM
13-07-2020 6:20 PM
13-07-2020 6:22 PM
- My Order
