PN broadband/own router. Ordered fibre, received hub one: can I install it before fibre activation?
FIXED- Subscribe to RSS Feed
- My Order
- PN broadband/own router. Ordered fibre, received h...
12-10-2018 2:10 PM
I tried to put it all in the title, fairly simple yes/no question, but there seem to be various answers on the forum and can't find it in instructions - which I know is probably me being blind - but if anyone knows for sure that would be great, and I can do it this weekend without time pressure.
Thanks in advance
Fixed! Go to the fix.
Re: PN broadband/own router. Ordered fibre, received hub one: can I install it before fibre activati
12-10-2018 2:19 PM
Simple answer - yes.
12-10-2018 2:19 PM
Yes. The Hub one will work on both ADSL ( normal broadband ) and VDSL ( fibre ) connections.
It will automatically detect the change to VDSL when your fibre order completes.
12-10-2018 2:36 PM
Great, many thanks to both of you for that. I'll get on!
- My Order
