PN broadband/own router. Ordered fibre, received hub one: can I install it before fibre activation?
LB001
I tried to put it all in the title, fairly simple yes/no question, but there seem to be various answers on the forum and can't find it in instructions - which I know is probably me being blind - but if anyone knows for sure that would be great, and I can do it this weekend without time pressure.
Thanks in advance
Fixes: 33
Re: PN broadband/own router. Ordered fibre, received hub one: can I install it before fibre activati
Simple answer - yes.
Fixes: 56
Yes. The Hub one will work on both ADSL ( normal broadband ) and VDSL ( fibre ) connections.
It will automatically detect the change to VDSL when your fibre order completes.
LB001
Great, many thanks to both of you for that.  I'll get on!
