Ordering a new BB service but allocate current phone number to VoIP
- My Order
- Ordering a new BB service but allocate current pho...
16-08-2021 12:00 AM - edited 16-08-2021 12:03 AM
I am currently on Sky fibre BB plus SoGEA phone (plugs in to Sky router), and contract period is over.
I noticed in this and this thread that it seems 'special' measures are required to join from a SoGEA connection and retain number. However, I would prefer to join PN for Fibre Extra BB only, as I want my phone service and current number via a VoIP provider.
How do I achieve this?
Re: Ordering a new BB service but allocate current phone number to VoIP
16-08-2021 3:07 PM
We wouldn't be able to support that I'm afraid @aks100.
While we can take over SOGEA lines, through a slightly different process, we don't support VoIP.
16-08-2021 4:15 PM
Hi Adam,
Thanks for your reply.
I would like to sign up for BB with PN, and I would like my current telephone number to be ported to Sipgate. I don't need VoIP from PN, just my long established phone number to be release. Is this possible?
Cheers
16-08-2021 4:45 PM
Hi @aks100,
I would recommend contacting Sipgate to see if they would be able to transfer your current number over to them.
16-08-2021 5:02 PM
Hi Alex,
Yes Sipgate confirmed they can take my number, not a problem.
Here is the actual problem that I don't understand how to get around:
* Ask Sipgate to take my number from Sky - they confirmed it's possible
* Sky *will* release my number, but * I believe * also terminate my whole service, hence I'll have no broadband either
What I'd like to do is trandfer my broadband to PN, and transfer my phone number out to Sipgate. One possible solution is:
* I transfer phone and BB to PN on a new contract
* Once up and running, I transfer my number only to Sipgate, whilst maintaining my BB with PN
* I want to avoid any downtime if possible
So, will PN allow me to transfer my number out with broadband service disruption?
16-08-2021 5:34 PM
@aks100 What you are trying to do will not be easy, the only way is to transfer your number to Sipgate from Sky which will cease your Sky services, then order a new FTTC service from Plusnet so there will be a significant gap before you get Broadband again, probably at least 10 working days. You also need to check there is availability at your cabinet so you don't lose your FTTC cab connection. If there is a waiting list someone else may get it.
There actually is a way to do this through Openreach or BT Wholesale (not sure which) called something like number port with renumber but I don't think Plusnet use it. This would port your existing number and give your line a new one.
16-08-2021 5:37 PM
This would be ideal, if possible 😀.
16-08-2021 6:40 PM
@aks100 But as I said I don't believe Plusnet can do it either because they don't know it exists or more likely it is not supported by their archaic ordering system.🙁
16-08-2021 6:52 PM
AFAIK there is only one ISP who will order a 'renumber with number export', that is ,A & A , and they will only do it to port the number to their Voip product
16-08-2021 8:17 PM
18-08-2021 10:25 AM
Yes, I think the only safe way is tthe second line option, which seems ridculous.
However, I decided to keep it simple and sign [back] up with Plusnet for Fibre Extra BB and phone with anytime calls.
Thanks all for the comments and suggestions.
Porting number from Sky SoGEA to Plusnet (number invalid)
18-08-2021 10:43 AM
Hi support team,
I received a notifiction that my number is invalid - but it is in fact active and working fine. It is however on a Sky SoGEA (ATA connection on the router), and I read in this thread that you need to take additional steps to port the number from Sky.
I have updated ticket #217192200, but have not received any confirmation that my number will be ported successfully. I certainly hope it can be!
Cheers
Re: Porting number from Sky SoGEA to Plusnet (number invalid)
18-08-2021 10:49 AM
Moderators Note
Topics from same OP merged to keep all info in one place.
18-08-2021 12:10 PM
Hi @aks100
Looks like our Provisioning Team have picked this up today and an order has been placed to take over the working line, while retaining the number. I've checked up on the orders and both phone and broadband haven't matched up together just yet, though this can take 24-58 hours. Our prov team will monitor the open Ticket and will advise you on any updates on the open ticket.
18-08-2021 1:10 PM
That's great, thanks Adam!
- My Order
