Ordered over a month ago
- My Order
- Ordered over a month ago
04-07-2018 6:24 PM
I ordered broadband back in may now a new broadband account moving from a different supplier and I have still heard nothing on when to expect it all to start evertime I try to chat on line it is unavailable or busy you have taken the first money that was paid on card when signed up... think is a bit long to be waiting now with no information on what is happening anyone know if I cancel now as it is taking so long if I will get that money back.. think I need to find someone that won't take forever to switch over with no contact
Re: Ordered over a month ago
04-07-2018 7:02 PM
19-07-2018 8:15 AM
19-07-2018 11:58 AM
19-07-2018 4:28 PM
19-07-2018 4:58 PM
19-07-2018 5:42 PM
19-07-2018 5:55 PM
@Chelle12 If you're on a Fibre product then providing it's a Home hub 5 or a Smart Hub then it will work , see here https://community.plus.net/t5/Broadband/BT-Home-Hub-6-Smart-Hub-on-PlusNet/m-p/1415464#M312705 for how to set it up
If you're on a normal ADSL product then just about any BT hub will work, see here
https://community.plus.net/t5/My-Router/Use-a-BT-Hub-2-3-4-or-5-on-a-Plusnet-connection/td-p/1192234
20-07-2018 9:27 AM
HI @Chelle12
Thanks for coming back to us. I can see that your PN router was dispatched today so should be with you very soon.
In the interim, the very helpful links provided by @MisterW should get you online with your BT router.
If you need any help, please just reply here and help will be on hand.
Best wishes,
Dave
