Ordered new service yesterday - text from open reach today
- My Order
- Re: Ordered new service yesterday - text from open...
a week ago
got a txt from Openreach.
trying to reply as requests and all its doing is this.
technology for the win
Re: Ordered new service yesterday - text from open reach today
Thursday
@ColinKent it could be a temporary problem with either the Openreach service or the O2 network.
Do text messages to other numbers work ok ?
Thursday
txt to other works just fine.
Thursday
Is this the issue discussed recently regarding BTOR using MMS messaging rather than plain SMS?
Thursday
@Townman wrote:
@MisterW
i'm trying to reply via my iPhone if that's of any interest.
i'm moving across from Talk Talk due them not being able to provide satisfactory support.
It would be somewhat frustrating to be left without a service as i can't reply to a txt from OpenReach.
Thursday
Strange, as I had zero issues doing exactly that when my FTTP installation was done.
Thursday
Is it going to cause any issues with my service going live ?
Thursday
Thursday
spoke to PN support and they were aware of the SMS MMS situation.
So that's a positive.
Thursday - last edited Thursday
Have you checked the setting for the message app?
Not iPhone user but check if there is an setting which looks wrong for just SMS sending?
Other than that I would suggest phoning plusnet
Thursday
@Dan_the_Van - good call
@ColinKent - check this...
Thursday
Moderators Note
This topic has been moved from Full Fibre to My Order
Thursday
tried several variations of turning on/off
iMessage/MMS/SMS
nothing made any difference.
However i have spoken to support over the phone and they have confirmed this should not be an issue and it all looks clear at their end.
Thursday
@ColinKent is this an FTTP order where an ONT already exists in the property ?
If so, then Openreach will try to test that the ONT is working. The initial text is to check you have access, once confirmed they will then ask you to make sure the ONT is powered up. So if you do have access, then check it is powered and leave it so.
If Openreach can't test the ONT , they will change the order to 'engineer required' which will likely delay activation.
Thursday
yes there is
i have a FF 500/80 with Talk Talk.
and it's all powered on.
the line has always been rock solid..
it just whenever there is a fault (not often) i get stuck in this merry-go-round with Talk Talk
Hence why im moving.
- My Order
