Order tracker not showing current order.
tonycollinet
Hi, All
I eventually found a link to the order tracker - but it is not showing anything about my current order. Just some old info with a really weird set of dates without year.
1 - why is there no link from my account directly to the order tracker - or is it there and I just can't find it?
2 - what needs to be done to show my current order in the tracker?
Cheers
Ant.
4 REPLIES 4
Fixes: 582
Re: Order tracker not showing current order.
ISTR that the order tracker can be a bit 'tardy' in updating. If its a recent order then that may be the problem.
tonycollinet
Thanks for your reply.
The order was placed Sunday evening (22nd) - does that class as recent? I've had a number of emails - including confirmed install date.
Cheers, Ant
RealAleMadrid
Fixes: 68
@tonycollinet  When I upgraded to Full Fibre a year ago the Order Tracker didn't show anything, you would be better off looking at your account tickets (Questions).  Try this link, it should go to the member centre login then redirect to the questions page.
https://www.plus.net/wizard/?p=search
Chris_S
Moved:
