Order tracker gobbledygook
diannelouise
Hello, the order tracker says "Your phone service will be active on 15th November 2016" for the phone line, but this for the Fibre "
Your order is due to complete
The engineer appointment to install your broadband service is booked for %appointmentDate% between %appointmentStartTime% and %appointmentFinishTime%."
Will the phone and broadband change at the same time, or will there be a period when I have phone but no internet?
MattyC
Champion
Fixes: 46
Re: Order tracker gobbledygook
Eeek, I'll get that fed back.
Both services are due to go live tomorrow, are you ok to let me know how you get on?
Matty
diannelouise
That's great thanks. I'll definitely let you know.
Thanks again.
diannelouise
All up and running, thanks.
Fixes: 251
Moderator's note by Mike (Mav): I have changed the fix to MattyC  as per message #2.
Forum Moderator and Customer
MattyC
Champion
Fixes: 46
Great stuff, thanks for confirming.
