Order status tracker confusing
dawebuser
Your order tracker doesn't seem to be in sync with your email and text notifications.
I've received an email and text confirming my phone line switch and broadband switch dates however the tracking still says we are checking your line leaving me concerned there's a problem with my order.
12 REPLIES 12
abails0105
Fixes: 60
Re: Order status tracker confusing
Hi @dawebuser
Thanks for getting in contact, I can see your orders are progressing smoothly and due for completion on 21/03/2018. Your router has been ordered and should be with you in the next few days. Apologies for the confusion there has been.
If you need any further assistance don't hesitate to let us know
 Alice Baillie
dawebuser
Many thanks for your help.
Fixes: 1,600
No problems at all.
Let us know how it goes.
dawebuser
I seem to have been switched over to Plusnet Phone however no broadband as of yet my broadband isn't working from my previous provider (Vodafone) either.
Is it just a case of wait or should this be live now ?
Fixes: 1,600
Doesn't look like your account activated automatically when the order completed.
I've just done that for you. Can you connect now?
dawebuser
All looking good , many thanks for your assistance.
Check out my Speedtest result! How fast is your internet? http://www.speedtest.net/my-result/a/3761818914
Fixes: 1,600
Glad to hear that!
Speeds looking spot on. Thumbs_Up
dawebuser
My broadband and phone is all still running fine however a question if I may.
I looked today on the BT Checker using my phone number I'm currently connected to Plusnet on and it no longer shows fibre available however using the house number and postcode does. Is this normal ?
I was merely looking to see if there was any mention of G.fast on our exchange but was concerned this could impact me at contract end if I wished to look elsewhere.
To be clear everything is working fine so don't want anything done that will impact this but would appreciate the issue looking into if possible.
Fixes: 1,600
Glad to hear your service is running as it should be.
About the broadband availability for your telephone number I've raised this with our suppliers to investigate.
We'll be in touch via this ticket when we have an update.
dawebuser
@Gandalf
Sorry to bother you again , but the original issue seems to have reared its head again on the BT Wholesale checker.
Not sure whether this would cause the issue but contractors appear to be fitting a G.fast pod to the cab we are connected to up the road. Would this cause an issue on the checker ?
dawebuser
@Gandalf
It's the issue in message 9 rather than the original post.
Sorry for confusion.
Fixes: 1,600
It's possible that it's because of the cabinet being upgraded if the records are in the process of being updated.
But thanks for flagging, I've raised this to our suppliers to investigate. Should know more next week.
