Order confirmed 25th April. Result=silence.
As per the heading, initial payment taken and since then nothing.
I hope my 14 day refusal dates from the time of connection.
I'm not getting good vibes from the slowness of movement, and lack of explanation.
T.I.A.
3 REPLIES 3
Aspiring Champion
Fixes: 30
Re: Order confirmed 25th April. Result=silence.
Good Morning,
I'm sorry about the lack of updates, it seems our automated systems hadn't placed the takeover as there are 2 lines showing at your address with your current provider, I have passed this back internally to be looked into as it should have flagged the problem to us.
I've emailed your previous provider and requested they identify which of the 2 lines are yours, once we receive a response we can get the ball rolling for you and get you over 14 days from when they respond to us, with it being a weekend however I wouldn't expect a response til around midweek at the earliest depending on how quickly the provider processes our request.
I've got two lines and 2 providers
01892 XXX068 is with Sky. Moving to you.
01892 XXX962 is with Talktalk. Staying as they've been 100% reliable since they were Tiscali.
Both are bog standard Broadband with Telephone. I'm moving 1 to fibre, then the other. I used to share my house, now I don't, but found I liked having 2 lines etc.
Aspiring Champion
Fixes: 30
Thanks for that, both line identifiers were listed as owned by the same provider, which is odd to say you have 2 different providers, I'll make sure the correct line is identified shortly however Smiley
I am one for multiple lines myself, load balanced with failover to single routes if any drops occur
